 Managing bridle parts
  | Command | Path |
| Manage Bridle Parts | Spotlight > Rigging |
The Manage Bridle Parts dialog box provides information about the bridle inventory. Select which parts can be used in the drawing, and edit their properties if needed.
To view and manage the bridle inventory:
Select the command.
The Manage Bridle Parts dialog box opens.
| Parameter | Description |
| Bridle Parts List | Displays the properties of the bridle parts |
| Use | Select which bridle parts can be used in the drawing. A check mark indicates that the part is available for use. Click in the Use column to add or remove the check mark. |
| Count | Indicates how many of that bridle part are present in the drawing |
| Name | Displays the bridle part name |
| Short name | Displays the shortened bridle part name, for use in bridle assembly diagrams |
| Symbol | Displays the name of the bridle part symbol |
| Length | Displays the length of the bridle part |
| Delta Length | For STAC Chain, displays the length of a single chain link; the chain length can be adjusted by intervals of this amount. |
| Minimum Length | For STAC Chains, displays the minimum length |
| Maximum Length | For STAC Chains, displays the maximum length |
| Allowable Force | Displays the maximum force that can be applied to the bridle part |
| Type | Displays the type of the bridle part |
| Filter Text | Enter text to filter the list by name |
| Filter Type | Filters the parts list by the selected part types. Select the check boxes to toggle the selections, or select All to display all part types. |
| Preview | Displays the symbol of the bridle part selected from the list |
| Opens the Columns dialog box, to toggle the display of columns in the bridle parts list | |
| Update | Traverses the symbols in the Stock Bridle Material folder, updating the bridle parts list |
Advanced users can edit, add, or remove items from the bridle parts list. Edit the symbols in the Stock Bridle Material folder in the [User]\Libraries\Defaults folder. Click Update in the Manage Bridle Parts dialog box to refresh the bridle parts list.
To edit the properties of an item in the bridle parts list, double-click on the row item. The Edit Bridle Part dialog box opens. The available properties depend on the bridle part. Edit the properties as needed, and click OK.
Be cautious when editing the Length of a bridle part that is currently used in the drawing; existing bridles may become invalid.
Click OK to update the bridle inventory, as well as the drawing, with any changes from the bridle parts list.
